2007 Softail dyno #'s
2007 Softail dyno #'s Rush 2.0 slip-ons *UPDATE*
Here is the before and after dyno sheet. The red lines are the stock baseline readings. The blue lines are with the addition of Rush 2.0 slip on mufflers. No other changes made. Note that the correction factor is STD.
The following sheet is the a/f ratio for the roll-on (closed loop) tests.
The a/f ratio was virtually identical before and after the Rush muffler install.
Jersey Drew
2014-2023 Touring Models
21
05-10-2017 05:24 AM
Scottzp
02-20-2014 05:49 PM
