Screaming Eagle or V&H
Looking for some advice. I have an 09 Fatboy and am looking to upgrade the pipes. I really want a set of V&H Softail Duals. I called the stealer and it is going to be $1200 for the pipes, tuner, installation, and tuning. I don't know if I am ready to drop that much on some pipes. The Screaming Eagle slip-ons are considerably less expensive and do not need tuning. Are the V&H worth paying around four times as much? A friend of mine suggested that I put the Screaming Eagles on until I was ready for the V&H and then Ebay the Screaming Eagles. I'll leave it open for more suggestions. Thanks in advance.
Do the pipes......
Do the work yourself and save big $$$, and the installation is fairly easy. You'll need your pipes......buy them from a forum vendor or ebay; the dealer will stiff you royally. You'll need a tuner......choose the one you want, SERT, PCIII, whatever. Easy to mount and install, and you can download a map from the manufacturers website for your setup, or buy it with the map preloaded from someone like Fuelmoto. You'll need a free flowing air cleaner......tons of them on ebay or from members here who have upgraded. I myself have a Screaming Eagle Stage I air cleaner with the upgraded K&N filter that's lying on a shelf unused.
The preloaded maps will be very close and if you want you can have a dyno run and custom map at a later date.
