Rear tire project on '90 softail
Old 11-05-2008, 08:35 AM
sgt.lopez's Avatar
sgt.lopez
sgt.lopez is offline
Default Rear tire project on '90 softail
Ok heres the deal. Im stuck in Iraq with alot of time to figure out how to tinker with my newly aquired (bought off ebay) softail.
I've searched the web for a fatter tire kit. Came across DM Customs kit. Being the guy that I am I think I can do it better for less. So far Ive come up with this. Im going to use a 2000 softail swing arm. Run a 18x5.5 rim and maybe a 180-200mm tire. I want to keep everything else stock, accept the fender and fender mounts. Any one got any idea as to what size spacers I might need? Or any other tips that might save a guy some a$$ pain later. Or just any other cool tips on an old evo.
-Joe
Old 11-05-2008, 08:48 AM
hotrod351's Avatar
hotrod351
hotrod351 is offline
i have a 1990 softail also. didnt know you could swap out the swingarm for a 2000 model. but how does that affect the rear drive belt, right now, with a 160 rear, im 1/4 inch away from the rear drive belt.
Old 11-05-2008, 12:09 PM
sgt.lopez's Avatar
sgt.lopez
From what the dude at DM Customs tells me, a 2000 or newer swing arm will allow a 18x5.5 rim with a 200mm. I don't know that the swing arm from a '06+ would work though. They didn't say anything about offsetting anything. It will require removal of the horns on the back. And some spacers.
Old 11-05-2008, 03:05 PM
Harley_Dude's Avatar
Harley_Dude
Harley_Dude is offline
Get a strutless fender, it will make your life a lot easier. The only difference on the 2006+ swingarm is the caliper mount has been shaved. You will need a narrower belt or most likely a chain if you go with the 200mm.
Old 11-05-2008, 05:05 PM
willyp's Avatar
willyp
willyp is offline
Sgt Lopez, I looked at the DM set up from iraq as well. Not sure about your 90’ but I have a 99’ night train that I put a 180 metzeler on using the stock swing arm. Im running a 18 X 5.5 inch rear wheel with a strutless Russ Wernimont fender. Had to cut the frame horns off. I used a 70 tooth ¾ inch pulley and a 2006 HD 133 tooth belt. Needed new rear spacers. Because of the 70 tooth pulley I could no longer use my belt guard so I cut the off the tabs. I think I like it better anyway. Good luck
Old 11-06-2008, 10:17 AM
tk353's Avatar
tk353
tk353 is offline
I have a Metzler tire chart if that will help. It has the mods for larger tires. I can email it if you pm me with your email address.
Old 11-06-2008, 12:09 PM
sgt.lopez's Avatar
sgt.lopez
Thanks all for the input guys.
Elvira
04-06-2020 12:08 PM
Easy 13
Wheels/Tires
01-01-2016 08:31 PM
Jay-HD-KC
04-24-2015 08:13 PM
newrider69
10-28-2008 07:36 PM
highbars92
EVO
02-06-2008 11:09 AM
Quick Reply: Rear tire project on '90 softail
