Will 96ci Jugs work on 88ci Fatboy
I found a set of 96ci cylinders and pistons from an 08 with very low miles. Can I install these on a 06 Fatboy? I read that for 96 jugs to work on an 88 the crank also needs to be swapped? If thats the case, its not worth it... The seller says they will fit without this change?
If these will fit, is it worth the hassle, would the performance improvement be obvious? What else would I need to do? Any head work necessary? Will I need to change the injectors or add a fuel management unit (PCIII ?) Anything else?
Im thinking if these will work I may also add a cam to complement it? I would like to add more low and mid range torque.
yes. they use the 103" jugs and piston. So if you put 103" jugs and pistons on a 88" you get a 95". that's why you have to change the crank, jugs and pistons on a 88" to get a 103".
