Rocker tank lift w/ Danny Gray seat?
here is my bike with a 2 inch tank lift and the trick seat. notice how much better it looks. the danny gray seat is lower then the trick seat so i would think it would look even better.
i tried doing the 3 inch tank lift but the wires for the speedo seemed like they wouldn't reach (there is not enough slack in them to cover the 3 inches). so you might have to re-wire your speedometer....(not worth it)
2 inches is just fine.
I did a 2" and had the option of doing the 3" with the $25 kit I bought on eBay, but would have had issues with wiring, etc. I cut off the 2nd hole on the brackets, painted with paint the body shop had leftover from the fender smoothing and whalah...
Subtle, but really makes a HUGE difference when paired with the DG seat (which I just installed recently). Lines up the tank with the frame nicely.
I'll take pics tonight if it's not raining out as I've been wanting to do a mini photoshoot.
There doesn't seem to be any negative side effects of my 2" tank lift on my rocker. I was concerned if it would affect the mileage to empty and I believe it is just as accurate as it was before the lift.
Gas Guage
It does effect the "miles to empty" reading. My first ride after the lift, I fouund myself in some pretty desolate territory when the warning lite came on. I rode several miles in a state of panic wondering how far I would have to walk to find gas. I made it to a station about 5 miles after I read 0 miles to empty and put just barely over 4 gallons in a five gallon tank. The way I see it now is that I just have a larger safty zone.
