Ideas on how to remove stubborn baffle from big radius pipes?
I bought the BCT baffles for my big radius pipes and attempted the install last night.
Problem was the first baffle came out with no issues but the second one would not budge at all. Even after applying PB Blaster and letting it set for some time.
I also removed the button screw that holds the baffle in the pipe and threaded it back in from the inside of the baffle so that I would have something to grab on to using vice grips but still couldn't budge it.
I also got a cloths hanger and bent it so that I could run it up into the pipe and when I would pull back on the cloths hanger it would catch on the button bolt sticking out of the baffle and that wouldn't budge it either.
Any other ideas on what to do?
PaulG75 (06-10-2021)
Thanks for the help!
I know what your talking about. Was it the top pipe? I sprayed the **** out of it with wd-40 and let it sit then started the bike to heat it up. Took a good hr to get it out with a metal hanger that was split like a Y and I made hooks on the ends. Gave the hanger to a friend for the same thing and his came right out no problem. Go figure!
I guess I will try again tonight using a ton of wd-40 this time and the "ghetto slide hammer" idea mojojones gave me.
Any issues with spraying a ton of wd-40 in there and then starting the bike getting the pipes hot? Seems like a good way to start a fire, no?
had the same problem. it will come out. here is what i did. put a 1" bolt back into threads from baffles on the inside. heated pipes up. sprayed with wd40. used a 1 1/2" box end wrench banged back and forth pulling. then attached vice grips to handle on box wrench at 90 degree angle and beat out with a mallet. it took me about 20 minutes once i got the set up. hope this helps.
