Passing lights on a Fatboy
Old 11-13-2008, 09:05 PM
nickm's Avatar
nickm
nickm is offline
Default Passing lights on a Fatboy
Can someone take a picture of the passing lights mounted on a Fatboy with a windshield (quick release)? I can’t seem to figure out if the lights go on; before the quick release bolt things or after.
If someone has a scan of the instructions that would be great.
Thanks
Old 11-13-2008, 09:42 PM
wildman67's Avatar
wildman67
wildman67 is offline
I Have both will post a pic tommorow if no one else doe's first. sorry I aint takin pic's in awhile. but if I remember right it was light's first then bracket. then windsheild mount's.
Old 11-13-2008, 09:51 PM
sonar_chris's Avatar
sonar_chris
sonar_chris is offline
Thanks
The quick release rubber gromits go on the outside of where the passing lamps attach to the fork legs.
Old 11-14-2008, 01:51 AM
Buddy7394's Avatar
Buddy7394
Buddy7394 is offline
Here's a close-up view of my Old FatBoy pass-lamp set-up. You should be able to see the docking grommet on the top outside of the bracket...(as previously mentioned)..click twice for biggest image...
PS: my grometts are A-1 condition, the close-up shows a shadow, which looks like it's damaged..
Attached Thumbnails Passing lights on a Fatboy-044-2-copy.jpg   Passing lights on a Fatboy-044-2-.jpg
Old 11-14-2008, 03:49 AM
nickm's Avatar
nickm
nickm is offline
That the pic I was looking for. Thanks.
Here are the lights I bought. https://www.hdforums.com/forum/motorcycle-parts-for-sale-misc-parts/288458-harley-driving-lights.html
I put the lights on the bike and I don't have as much room as you do under the light. And it was a TIGHT fit to get the light bracket on. And to top it off. If I do get the light bar mounted I think the lower windshield mounting legs my not fit around the light bar on. The lower leg of the windshield mount seems like it hits the light bar bracket.
I am at work right now, but Ill take another look this evening when I get up.
Thanks for posting the pix.
Old 11-14-2008, 11:09 AM
jneubig's Avatar
jneubig
jneubig is offline
I had the same issue with the shield hitting the light bar. I switched to the Heritage screen (it's wider to accomodate the light bar) and all is good now.
Old 11-14-2008, 12:27 PM
What 'Chew Talkin' Bout Willis's Avatar
What 'Chew Talkin' Bout Willis is offline
Here's my setup on my Fatboy..with HD removable windshield. No problems.
Old 11-14-2008, 04:12 PM
nickm's Avatar
nickm
nickm is offline
Hey Boss, can you take a picture of the brackets on your windshield. Ill call my uncle and see if I can barrow his windshield next weekend. I am working nights this weekend.
Do you have pictures of your windshield brackets. From what Ive read there are 2 types of brackets. But I am not sure either one will fit. But to be honest I have only seen pictures of 1 type; the type I have. So the ones you have may work. Also, it seems your lights are closer to the center light than the picture above. Thats about how close mine are.
One last thing, does anyone have the spacers and longer mounting screws? I am usng grade 8 screws ti fit this stuff on my bike. I didnt get the longer screws with the light set.
Thanks
-Nick
Old 11-14-2008, 04:19 PM
nickm's Avatar
nickm
nickm is offline
Here is my work in progress. Yeah I have to lower the trunk
Old 11-14-2008, 11:17 PM
Buddy7394's Avatar
Buddy7394
nickm-
FWIW: All softails are not created equal.. ie: The FLST, & the FXST, all models...Softails but quite different frontends..
The Heritage & FatBoys use the pass lamp bracket (oem) 58082-87 for 1986-2008 Heritage & FatBoy
And then there is an aftermarket bracket that looks almost the same, but not quite for 1984-2008 FXST (all models), & 1980-84 FXWG....
Also, my windshield uses spring-wire clips that lock the top in.
Maybe you can contact the seller to see which softail he was using this bracket on ??
Quick Reply: Passing lights on a Fatboy
