Need some gasket help guys
Doing service on my 04 FB. When I got to the primary, expecting to find a simple o-ring gasket for the cover, I found this.
This is not what the service manual looks like. Can I just reuse this, or should I go get the o-ring, or?????
BTW, looks like who ever did the last sevice used antiseize on all the bolts and drain plugs, but the manual does not state to use it.
Thanks
Ernie
Thanks
Ernie
I have the same type of gasket on my evo. I keep a spare and when I service the bike, I use the old one until it begins to leak then I change it and go by another spane. I have been able to use mine up to 3 times. But only torque to specs. Do not overtightten. I use just a little blue loctite on my bolts.
I only use one small drop of blue loctite. Torque specs are minimal for these screws and these machines do vibrate. Never had a problem getting mine off. I have had problems getting my buddy's off, because they overtighten them.
I think they are like 15 bucks a piece, I've had mine off and on 3 times now and don't plan on replacing until it leaks. Saved 45 bucks already. There isn't any oil pressure in there, just a splash oil bath. And I use blue loctite and tourqed. I don't want the damn thing to fall off a hundred miles from home... Like wideglide said these things do vibrate.
