Pulley question
You might get away with it and never have any problem, then again you might not..
Being a retired machine repairman the only time we used a wider pulley or narrow belt was with a crowned pulley, that way the belt stayed in the center, but if you have a flat belt pulley (which it is) and it not aliened perfectly 90* to belt, it (belt) will want to climb the pulley to the high side and then possibly walk even further. this would then cause more tension on the tight side of the belt instead of equal across the belt that could cause premature failure or even come off the pulley ... Not trying to scare U but it could ?? be serious.
Now that said, I have no experience with the Harley belt or pulley setup but with the price of them I would talk with the best and most trusted wrench I know and ask him. Could save you some money and or your life..... AND MOST OF ALL, PIECE OF MIND..
