Air cleaner install questions
Its very straight forward, and anubisss is right, you do not need to remove the tank.
Even a rank novice should be able to change it out in under 20 minutes.
I think there are only a total of 6 screws/bolts that hold it on. 1 screw for the cover, 3 for the filter, and 2 bolts that go into the heads for the backing plate.
But if oldgeezer is right, and I suspect he may be heed his advise and make damn sure you use the right size. For some unknown reason Harley and the tool makers seem to be doing us the dirty. The tool makers will sell you a set of Torx bits/wrenches that contain T-10, 15, 20, 25, 30, 35, 40, 45, 50, and even 55 sizes. But Harley in its infinate insanity uses T-27 sized bolts for some things. A T-25 will "fit" but it will also rip the head a new one if its not already loose thus leaving you with a stripped out head.
So make sure your using the right size and its fully inserted into the bolt head, lightly tap it in if you have to make sure, or it will give you a small nightmare trying to get it out after its damaged.
