Fat Boy instead of Rocker ??
Well, you can always get an aftermarket backrest installed on a Fatboy as well, but at least a touring scoot like the Road King would provide you the rubber mounted engine with better suspension and smoother ride than you would get with a stock Fatboy. I own a Fatboy and absolutely love it, but if I had a back problem like that, I'd probably be leaning toward a Road King.
I ride a Fat Boy and it rides pretty well, I think. However, with back problems you're main obstacle is going to be your riding position. A Fat Boy with some pull back risers and a good seat will probably work pretty well for you. That being said, you could probably make some mods to your Rocker to get into a better riding position. Unless you absolutely think that you won't be able to stand the Rocker any more, I'd look into that before I'd look into changing bikes.
I suggest you rent one and try it out first. The FatBoy is a good bike and has a low center of gravity, but is still not the most comfortable. It is easy to handle, I'm 5'7" and weigh 160. I don't have any problems with it, but then I don't have a bad back. If you just ride locally, then it might be a good pick for you. If you plan on long rides then maybe not.
The newer Fat Boys have a very smooth running engine, I'm not polished up on Harley facts just yet, but I believe it's a counter balanced engine? I agree with the backrest part. I wish I had one for solo rides, but you're looking at having to buy a new seat with a backrest. If ya get a Street Glide it has a hole in the stock seat for a driver backrest to be added. Not sure if the RK has that same style seat that a backrest can be added to easily??
I've got a sundowner seat for my Street Glide for the long rides when I add the back rest.
Stock SG sits lower than a stock RK btw.
I'd try out some mods on the Rocker first if $ is a consideration. Otherwise I agree you should go for one of the touring bikes.
Good Luck,
Primo
You may not want to jump the gun on it. A lot of riders (self included) have herniated discs and are still able to ride without issue. You just have to give your self time to heal. I have 2 herniated discs and I ride a Softail.
Then again it's always nice to have an excuse to buy something new.
