66 tooth pulley different then 65 tooth ?
IOW, it will feel like you have slightly more low-end grunt, at the expense of turning slightly higher revs on the highway. As far as the axle adjustment, your new pulley is slightly smaller diameter, so to take up the slack on the belt you have to move the adjuster slightly towards the rear. If it's already all the way to the rear, then you're SOL lol!
Capiche?
Capiche?
Capiche?
Capiche?
Imo
I do not think that one tooth is worth the money it would cost for a pulley and the time it would take to change it out. As far as if you were needing a pulley and was buying something I would give this advice.
A 66T will give a fraction of second in the quarter, maybe but would burn a fraction of a dollar more gas on a trip.
The factors you should watch for is:
* The width of the pulley and is your belt going to fit.
* I believe all HD pulleys are 39 pitch so that is not a problem
* Make sure if you are not buying a HD pulley that the aftermarket (belt part edge) pulley is hard chromed. If it is not that the soft aluminum pulley will wear out in 5K miles. Many aftermarket pulleys are not properly plated on the belt surface contact edge.
