V&H BS Staggered
V&H BS Staggered
Found them on Ebay for $440 (little hesitant to buy on ebay though),
and found them at PhatPerformance.com for $515; at JPMotors.com for $506; at DennisKirk.com
for $479; and various other places for more $
Anyone know of any better deals out there for them?
And, again, this is relatively easy enough that it can be a D-I-Y project?
I've been told that it is as long as I don't also plan any mods to the engine? I might in the future
but for right now I just want this exhaust. If I have any mods performed to the engine in the
future I will get it "mapped" at that time.
There was a pretty big discussion on this on a thread I started if you want to search for it. The skinny is, I ended up calling V&H and they recommended a high flow airfilter and fuel pack. Without those they said it would no run properly. If you want to just put exhausts on and nothing else, you are best to go with a slip-on.
Personally, I am getting these same pipes, a V&H fuel pack which I can configure myself, and an Arlen Ness Big Suck airfilter. These are only a few hundred more and the bike will run much better. (basically they said it wouldnt run right with just exhaust ..would sputter, backfire, and stall out) These are all fairly easy to install and V&H have some videos on their site as well.
Personally, I am getting these same pipes, a V&H fuel pack which I can configure myself, and an Arlen Ness Big Suck airfilter. These are only a few hundred more and the bike will run much better. These are all fairly easy to install and &H have some videos on their site as well.
Or will that need to be done too?
The Fuel Pack is the 'map'. You plug it in under the seat and put in a code that matches your bike (that you find on the fuel pack website) and it adjusts the fuel consistancy.
The fuel pack is like $250 and big suck was $150 or so if I'm remembering correctly. Get all three of these and do it yourself! Save a ton of money. I've never worked on a bike before in my life, but after a bunch of research I see that it's not that hard to install these at all. They give clear innstructions and the V&H cust service is top notch.
Do you have the URL for the fuel pack website?
I've got the same set up for my 06 Heritage (BSS, Fuelpak, Big Sucker). I bought everything from Eastern Performace. The fuelpak came with a booklet with all of the settings for your bike.
Installation was very straightforward - the pipes and AC were basically bolt-on direct replacements. For my model year, I did replace the stock flanges with thinner chrome ones. I also used the SE gaskets. I'm no mechanic but I was able to do this in my garage. For the fuelpak, just follow the instructions - it's very simple.
questions...
1. did you, or will I, need any special tools?
2. did the SE gaskets come with the exhaust? If not, I guess I can just get the from the local dealership?
3. how long did it take you to accomplish this?
4. no problems afterwards? you didn't have to end up getting it retuned or anything? and you've been happy with the setup?
5. you purchased the bigsucker from EasternPerformance too?
http://www.easternperformance.com/in...oducts_id=1695
Just want to make sure. Is this the right intake? Are there others? Or is this
widely considered the best of the bunch?
Also, baffle type? Standard right? One of the reasons I'm doing this is because
I want it louder... so I don't want the quiet baffle right?
