how to install Fuel tank nameplate 61776-61T with adpater kit 61740-90T
has anyone installed on of these tank nameplates on a softail 06 or later?
how did you do it, how hard was it, any advice?
looking at picking one of these for my hertiage softail 09, cause I am not a fan of the tank nameplate that is on there stock. Just trying to do my research and understand what needs to be done to make the switch myself.
thanks for you help
thanks for you help
I saw as per title of the post as well that there is an adapter kit...if I understood it right the adapter kit is the 2 sided sticktape type in the shape of the emblem to give it maximum adhesion.
Question though is...the tank nameplate has 2 holes for the screws originally used back in the days...does the adpter kit have fakes to pretend that it is screwed onto the tank? or what does one do with the screw holes? leave them empty? is there a way to make pretend that screws are in them if the adapter piece doesn't do this?
thanks
anyone got pics of theirs mounted?
thanks
thanks
thanks
