HP gain on 95'' kit
Old 01-13-2009, 02:35 PM
saintslax11's Avatar
saintslax11
saintslax11 is offline
Default HP gain on 95'' kit
Just lookin to see what kind of numbers you guys are getting with the 95 kit with 203 cams.
Old 01-14-2009, 03:57 AM
hpfatboy's Avatar
hpfatboy
hpfatboy is offline
Thumbs up
Not sure what numbers the 203s will get you. But i can tell you what numbers the WOODS-6 will get you.
Old 01-14-2009, 05:09 AM
06DEUCE's Avatar
06DEUCE
06DEUCE is offline
Getting my kit installed this week. with the 95" kit and 203 cams, street port on the heads and raised comp to 9:8 I should be at mid 90's for hp and 100+ on trq. if your going to do the 95" have the heads done!
Old 01-14-2009, 05:56 AM
Chazmanian's Avatar
Chazmanian
Chazmanian is offline
R.I.P. BROTHER
My stock compression no headwork 95" with 211's and a set of V&H Bigshots and a Heavy breather head to the Dyno in the AM.
I'm at 5500 elevation so my numbers will be skewered by the altitude but I think the dyno guy can get a corrected for sea-level number outta the thing.
I'll post the numbers. Having it tuned with the Direct Link.
Old 01-14-2009, 08:41 AM
saintslax11
Im kinda a trq *****!!! I am getting the heads done to. I know everybody's bike gives out different numbers due to who is doing the dyno and obviously who is wrenching the engine. Im running VH big radius with SE HB and PIII. I wanted a reliable engine with some good trq. I will be able to afford gear cams later in the year. After the air suspension and the engine work i could not afford a whole lotta engine work done. This pic is obviously before all the crap being done. Summer ride to the beach.
CHOOK (04-22-2020)
Old 01-14-2009, 09:23 AM
WARG's Avatar
WARG
WARG is offline
Interested in your numbers since I am planning a similar build. I want to go 95", gear drive cams (woods tw-6g) and possibly some head work. Torque and reliability are my goals as well.
Old 01-14-2009, 11:50 AM
Slowpoke84's Avatar
Slowpoke84
Slowpoke84 is offline
Not a clue, I wish I did! With all that's been done to my motor (see sig). But that's the way it was when I bought it used. I plan on taking it in for a quick dyno run sometime this Summer. Maybe at a ride or run that has $25 dynos. But a buddy of mine had pretty much the same work done to his FLHX and got 105 ft/lbs. I'd expect a little less from a Softail with the B motor.
hacker19
Exhaust System Topics
08-01-2011 08:51 PM
vzg5vw
03-02-2011 12:19 PM
DR. V-TWIN
09-07-2010 11:50 PM
masterblaster
10-14-2009 09:09 AM
jackinthebox
13
01-05-2009 09:53 PM
Quick Reply: HP gain on 95'' kit
Top
© 2024 MH Sub I, LLC dba Internet Brands
Follow Us
