The HD Deuce is a model not available in spanish market and would like to know if the rear fender would fit on my '07Fatboy with the stock 200 rear wheel.
Thank you.
My son just traded his 07 Deuce on 09 NT. I have'nt looked at a FB but the Deuce's tire is 160 and the 07 FB/NT ia 200 and he said the fender looks about 2" wider, so the deuce probably wont fit on the FB without using spacers. which may not be the look one would want..???
He loves the black on the night train and hated the Deuce because they are limited on almost all parts, only deuce parts fit deuce and a lot of add ons just are not available.
I know I'm way late to this post, but did I get that a Fat Boy rear fender will fit a Deuce if the fender struts are swapped? I have a 2003 Deuce with an FLST front fork and have a line on a complete Fat Boy fender/tank combo. If it all fits I would love to put it on!
I don't think the tank would fit without changing the seat as well. The Deuce tank is longer than the other Softails and the Deuce frame is different as well.
Those look like stock headers with Screaming Eagle slip on mufflers. I have a set of Screaming Eagle II slip on mufflers for the Deuce that are for sale, perfect condition, retail $295 for only $150 plus shipping.
I have a duece fender you can buy I don't have the struts iam useing them on my bike. the ferder will fit you will have to buy duece struts nicer looking strut then the fatboy ones I have a fatboy fender on my duece and it bolted right on your fatboy is a 07 the width is the same 07 fatboys run 200mm tyers I have a 06 fb fender on my bike.
.....so are you saying the fat boy fender bolted right on to your deuce...or how much fabrication did you have to do
I know a 200 is a very tight fit on a Deuce and unless you do a lot of shaving, inner strut braces, bolts, and the plastic cover will rub if you lower it at all.
