Side mount plate light wiring
Old 05-06-2009, 11:16 AM
nowbmw's Avatar
nowbmw
nowbmw is offline
Default Side mount plate light wiring
Which wire are you guys tapping into to run led licence plate bolts for your side mount. i want to tap into the harness that runs under the fender to the tail light. i have a 2007 fxstc.
Thanks
Brent
Old 05-06-2009, 11:30 AM
hogdiver96's Avatar
hogdiver96
hogdiver96 is offline
Run the wires to under your seat (theres a plug-n-play) joint box under there.
Earth the lights on a bolt holding something to the frame the live wire needs to be spliced in2 the run wire which i think is brown (someone will correct me) but if ubsure just keep sticking in the box until they light up (wont do any harm) have turn signals on when you do this if plate lights flash you got the wrong one
Old 05-06-2009, 12:19 PM
jknowlton's Avatar
jknowlton
jknowlton is offline
On my 07 FXSTB, the connector for the rear wiring harness (see attached pic for wiring diagram) on mine is:
BLUE = Run (I tapped the positive wires from the plate lights with a Posi-Tap connector, so no splicing or anything was very easy)
BLACK = Ground
Violet=Turn Signal
Yellow/Red=Brake
I took the negative and tied it to the screw that holds the ECM onto the fender.
If you dont want to take everything apart, I use the Posi-Tap, which is http://www.posi-lock.com/posiplug.html and got it from Custom Dynamics.
Attached Thumbnails Side mount plate light wiring-rearwiring2007softailmodels.jpg
Last edited by jknowlton; 05-06-2009 at 12:30 PM. Reason: added pic. / added info on Posi-Tap
voudoujoe
05-15-2015 01:56 PM
chuckles81
07-26-2014 11:46 PM
PearlWhiteGT
05-19-2011 11:52 PM
nowbmw
02-28-2009 12:57 AM
bumpdog
01-09-2008 06:34 PM
Quick Reply: Side mount plate light wiring
