Backfire threw carb
Old 04-20-2005, 01:12 AM
az_fxstc's Avatar
az_fxstc
az_fxstc is offline
2nd Gear
Default Backfire threw carb
I own a 1990 FXSTC. I just purchased this bike and it is my first Harley. I am having a problem with the bike back firing threw the carb when the bike is trying to maintain speed no matter what gear I'm in. The bike runs great as long as I'm accelerating. The bike is stock and has duel fish tail pipes.
I just went to get it smogged and it failed the Hydrocarbin test with a reading of 2201 ppm if this helps in any way.
Does any one have any ideas. I would greatly appreciate any input that can be offerd.
Old 06-08-2005, 04:48 AM
T wrecks's Avatar
T wrecks
T wrecks is offline
Default RE: Backfire threw carb
Hi az. I have a 94 FXSTC which I bought new. It does't backfire through the carb, but it does sometimes seem to starve for fuel. It happens normally just after I start the bike, warm or cold. I havn't had it stall yet, it just seems to miss a beat. It's always done this, so I'm prepared for it when it happens.
I hope you can find your problem.
Cheers
Old 06-08-2005, 07:25 AM
jtfrog's Avatar
jtfrog
jtfrog is offline
My 883 sporty was doing the same thing and my dealer shimmed the needle in the carb ?
Old 06-08-2005, 09:12 AM
T wrecks's Avatar
T wrecks
T wrecks is offline
Hi jt. Did your sporty backfire or starve for fuel??
Thanks mate
ORIGINAL: jtfrog
Old 06-08-2005, 09:19 AM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
Shimming the main jet needle up with 2-#4 brass washers will cure your problem
This link will give you some insight
http://www.nightrider.com/biketech/hd_cv_mods.htm
Old 06-10-2005, 06:28 PM
Longhair4life's Avatar
Longhair4life
Longhair4life is offline
Had a 92 fxstc and it did the same thing out my S&S
Old 06-10-2005, 08:55 PM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
This graph will give you an idea of when the different circuits are feeding the carb.The second one down is the one that you would richen by shimming it as stated above to eliminate the popping back in the cruise range
[IMG]local://upfiles/2318/3FFB3DA99E88401380C9448A7E7DCC0B.jpg[/IMG]
Huskerdoo
11-29-2016 03:05 PM
FullNelson
Carburetor Related
09-14-2013 05:29 PM
bluharley
EVO
34
11-29-2012 08:43 PM
scotitude
10-30-2010 11:10 PM
Sporster X 2
Exhaust System Topics
09-12-2009 11:21 AM
Quick Reply: Backfire threw carb
