I can't tell if my 09 fxstc has tubes or not. the front is laced but the tire has tubeless stamped on it, the rear is a disc with a tubeless radial tire.
A tire marked "tubeless" on a spoke wheel will not necessarily mean it is without since some tubeless tires can be used with a tube-type tire. Look at the valve: if it has a seal at the base, the rim is tubeless; if it has a valve with a nut at the base, it is tubed. Not all spoked wheels are "tubeless" but usually are. Should also be stamped on the rim "TUBELESS".
before I put aftermarket wheels on that allow me to go tubeless, I had new tires put on my OEM wheels, including a spoked front wheel. two days later, I had a blow out out just before entering a turn. pretty scary.
towed it to the dealer-cause? the tube was pinched between the tire and rim when it was installed, and it ripped a hole in the tube, causing rapid air release.
