6000k Bi-xenon HID kit installed on my Rocker
I installed a bi-xenon HID kit today on my 09 Rocker, the high beam function still works from the handlebar switch.
I played around with the kit and I was able to hide the ballast under the gas tank, it turned out to be a clean install.
Check out Howard at www.Motorcyclemetal.com if you are interested in a kit.
Does the bi-xenon bulb "move" for the high beam? How well does that work? Did you double sided taped the ballast to the tank?
Might want to check out the legality of the "retrofit kits" before you install them.
http://www.danielsternlighting.com/t...nversions.html
http://faqlight.carpassion.info/hl-hid-kits.htm
http://www.hella-press.de/search_det...e=e&newdir=eng
I know it's much brighter and probably illuminates the road better, but without replacing the optics, which were designed for a different type of bulb, how is the light dispersal pattern on the road? Are you blinding oncoming traffic? Effective HID systems have a projector lens which is designed to properly place the light pattern from the bulb onto the road:
Using the stock optics only grants you the brighter, whiter light but does not place the proper pattern on the road. This is the reason I've not put in an HID kit like this. I'm not slamming your install, that is not my intention at all so please don't take this that way.
Johnny Goodlife (12-15-2016)
The Truth
- "I know it's much brighter and probably illuminates the road better, but without replacing the optics, which were designed for a different type of bulb,"
- A quality kit had a converter on the bulb that reflects and aims the light onto the lamp for proper light focus pattern. The cheap e-Bay stuff may not.
- Are you blinding oncoming traffic?
- No, does cars blind other cars? Not all headlights are projection.
- Effective HID systems have a projector lens which is designed to properly place the light pattern from the bulb onto the road:
- This is not true. Please do some research and reading on this site and it will dispel the aforementioned statement. There is one of my customers who have posted both the side by side identical bikes of both light patterns and the result of both. Read and do your research decide!
- Using the stock optics only grants you the brighter, whiter light but does not place the proper pattern on the road.
- If you purchase a cheap kit available through sellers who are here today and gone tomorrow, this may be possible. My suggestion would be to stay off of e-Bay and talk to someone who actually works in motorcycles with HID. There are reasons why you can buy a kit for $20.00 and there are reasons why you can buy a HD MOCO kit for $500.
Danial Stern puts out this BS concerning lamps and patterns. I have as well as many members have posted photos of their HID in their bike. A little reading and more knowledge is needed. I will re-post a couple of previous photos that were provided by our members and there are over 100 threads from actual members who have done this very thing..
