Rocker Front Turn Signal wiring
Oh yeah - if your looking for some clamps Kuryakyn 49mm two piece fork mount clamps fit perfect, you will need to find some bolts though the ones that come with it are to large and do not sit flush against the forks. I ended up using the stock blinkers and just buzzed the top of the bolt heads with a dremel, if your into that.
get a pik or large paperclip & shove into where wire goes
until you hear/feel a snap the pull wire
it takes a little getin used to but once ya get one yer home free
good luck mon
But again, I totally dig it! Running without lights or mirrors in the front and loving it!
I don't blame ya. I am riding only with the LED arrays in the rear ( + head light) only and could ride just like that forever, but a few issues are: 1 - I feel the front blinker does help on 2 way highway left turns, 2 - My rear LEDs are always lit like the brake lights are on. I am assumiing it is because I have too much current on them, because there is no running lights in the front. This causes me to not have brake lights, and that is a BIG no-no. Must have brake lights! 3 - Cops!
I wired my LED plate, tail light & under frame blue lights to come on only at night with a switch. I wired my front mirrors with signals only no marker lights. Essentually in the day I only run my LED headlight.
Heres another side note...the rear turn/brake/running lamps on the Rocker are 6v (go figure) took me some time to figure this out, if your going to add any LEDs to the bike it would be a very wise decision to purchase the Badlands Illuminator (made for the Rocker specifically), best investment I ever made. Three major benefits/purpose of the badlands: 1. Although, the ad states just for the rear - it load balances the whole bike 2. It converts any dual element bulb or LED to a run/brake/turn 3. It gets rid of the 2xblue diodes (heavily wrapped in insulation) and all the rear fender wiring down to a total of 4 wires for the rear fender. The 2 diodes is the MoCo jerry rig for a load impedence which is specific for the 6 volt LED's as I mentioned earlier. Bottom line...cut the two heavily insulated diodes off (cause they will burn up) and get the Badlands illuminator once installed you will never have a circuit problem as I did off and on for a year.
