How many engine oil drain plugs are there?
Thanks for that information, this is what I kind of thought.
I noticed that the oil was black after I drove around the block and then check the oil level. I realized that I must not of drained all of the old oil out.
There must be another reason why this other plug is there and the manual does not refer to it when draining the oil. Maybe something to do with the oil pump loosing it's prime if all of the oil is drained out.
Anyone else have an opinion?
Uhh, did I screw up?
So I recently inherited my fathers 01 Softail. While doing the first oil change I did as I read a few others have, pulled the Crank plug. Only a few Oz's came out before I realized my mistake. I successfully managed to get it back in and re torqued. But do I need to refill it or is there a way to check the level inside? Might be a stupid question but if I don't ask I won't learn.
Received 1,211 Likes
I don't know about the newer engines, but in past days there were "drain" plugs at various points that were used for access during machining and other reasons. It was not uncommon to find the "drain" plug on the bottom of the crankcase to have been cross-threaded, stripped out, or tightened too much so that it cracked the relatively thin aluminum in that area. I, of course, had to learn that the hard way. My first bike had to be welded up in 14 places when I had the engine rebuilt. Some of the repairs were my fault, some were stress-related, and some were from playing Hot Rod Harry and blowing the trapdoor and lower right rear of the transmission case.
