Thunder Monster baffles & VANCE & Hines Big Radius
Old 07-22-2009, 06:05 AM
DaSham58's Avatar
DaSham58
DaSham58 is offline
Default Thunder Monster baffles & VANCE & Hines Big Radius
How big of a pain in the a$$ is it to take out the stock and put in the Monster baffles I put a set in a set of big shots no problem but where the Big Radius 2 into 2 has the curves
Old 07-22-2009, 08:15 PM
Ranger-Herb's Avatar
Ranger-Herb
Ranger-Herb is offline
not too bad, I stripped one of the allen head bolds that holds the baffle on. That caused me to have to take the pipe loose, but it was still pretty easy. Put the screw back in the baffle from the inside, just log enough not to go be in the pipe itself, and youll have something to get ahold of to pull the baffle out. there in there pretty tite.
Old 07-22-2009, 08:46 PM
m i k e's Avatar
m i k e
m i k e is offline
wd4o is gunna b yer friend
vise grips/slide hammer and away you go
Old 07-22-2009, 08:55 PM
DyNaBoB's Avatar
DyNaBoB
DyNaBoB is offline
just wut xzactly does the monster baffs do..........is it performance or just sound better????
Old 07-22-2009, 09:26 PM
Blk and Chrome's Avatar
Blk and Chrome
Blk and Chrome is offline
sounds deeper than the stock baffles. I like mine, they also add some back pressure .
Old 07-22-2009, 09:31 PM
DyNaBoB's Avatar
DyNaBoB
DyNaBoB is offline
oh i see......thanx blk&chrome
Old 07-22-2009, 10:47 PM
RocketRocker's Avatar
RocketRocker
RocketRocker is offline
I just went through that nightmare of removing the BR baffles....bottom one just basically almost fell out.....the top one made up for it. I would go with what mike posted....I dont have any fancy sliding hammers......I used hammer and big pair of tin snips (forged steel type). I am running no baffles and of course the appropriate map and love it....
Old 07-22-2009, 10:48 PM
RocketRocker
you can also just cut your baffles....same as the big city ones from what I was told
Old 07-23-2009, 03:23 AM
DaSham58's Avatar
DaSham58
DaSham58 is offline
How far back in the pipe is the stock ones? the bigshots I installed the factory ones was right at the end! I just had the these put on my 09 Heritage and havent had a chance to realy look I wont have to take the pipes back off will I ?
WildBill2566
Exhaust System Topics
07-29-2014 09:49 AM
michaelmitt
09-19-2010 08:55 PM
Flashman 22
08-03-2009 03:35 PM
urban cowboy
03-29-2007 07:38 AM
Quick Reply: Thunder Monster baffles & VANCE & Hines Big Radius
