what dot brake fluid?
I recently got some air in my rear brake line and after bleeding and changeing the fluid to dot 4 castrol it feels.....like it should be alittle tighter on the brake lever. thing is i changed the lever as i was doing it to the black billet harley one from the stock lever so dont really have anything to compaire to......I thought maybe theres a better brake fluid because im 99.9% sure theres no air in there now..... can you guys tell me what fluid you are running so i can get the right stuff?
Just got the Fat one services and Dot 4 is what the dealer used, flushed the lines right though so its all new fluid,Front and back, the pessure comes on a lot sooner both front and back, made a lot of noticable difference. ( Just noticed some riders on the forum have Dot 5, my dealer in Manchester used Dot 4, may be a model thing, I'd your the local dealer a call .
Ride safe
Reddog
Manchester UK
Ride safe
Reddog
Manchester UK
By 2006 all H-D's went to Dot 4. I used to like the Dot 5 silicone stuff only for the fact that it wouldn't damage paint and didn't draw moisture. Under a microscope (i've read) Dot 5 is full of tiny air bubbles. It's just part of it's make up-they never rise to the top. This accounts for the spongy feel when using dot 5. All new H-D's are Dot 4 and have a MUCH more solid feel, than the Dot 5 days. Reservoir level should be 1/4" from the top per the service manual (reservoir level has no effect on feel at the lever what so ever) it would have to be empty or completely full (not allowing for fluid relief port return and the pistons in the caliper would probably stick out)for this to happen. My 2cents-Glenn.
