Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Softail Models
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Sponsored by: Cajun Shine All
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 11-06-2009, 10:08 PM
azfathog17 azfathog17 is offline
Prospect
Default Front Brake Replacement - Fatboy
Yet another brake post. I get a lot of good information from this forum so I like share my "wrenching" experience when I think it might be useful. C'mon wrenching these machines part of the fun.
I replaced the front brakes yesterday at 9100 miles. It is pretty easy if you have a skinny c-clamp to push back the pistons. I wasted some time with one I had and ended up getting one at Home Depot to do it right. Before I pushed them back I cleaned the pistons and slide screw with BPC. They were black, probably from brake dust. One thing to watch is when you replace the reservoir cover after installing the new brakes some fluid will bleed out (small amount) when you tighten it. Just have a rag or paper towel ready to clean the residual fluid around the seal. Ride test was good. Brakes feel much better. Once interesting point is the screws on the front caliper are metric (10mm). I replaced mine with another set of HD brakes since they were on sale. I might try a set of Lyndall's next.
Next up will be the 10k service in a couple of months I am guessing.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
2008 FLSTF Fat Boy
V/H BSS, SE Intake/Filter, PCIII
....and a little skull chrome
Old 11-06-2009, 10:33 PM
WARG's Avatar
WARG WARG is offline
2006 Harley Davidson Fatboy
good write up, thanks for the info.
__________________
http://i110.photobucket.com/albums/n87/Toogie68/DSC_0917-1.jpg
2006 Fatboy - Always Under Construction
Blog: www.chasinwhitelines.blogspot.com
Gallery: http://hdforums.com/forum/members/wa...06-fatboy.html
Photobucket Gallery: http://s110.photobucket.com/albums/n87/Toogie68/
Old 11-06-2009, 11:06 PM
2kids3pets's Avatar
2kids3pets 2kids3pets is offline
Nice write up...good to see you cleaned the pistons before pushing them back many forget this or just don't know
__________________
Old 11-06-2009, 11:30 PM
harleyheaven harleyheaven is offline
Prospect
If you don't have the "skinny c-clamp" you can use a metal putty knife to compress the pistons.
__________________
2005 Anniversary Edition Fatboy 95" with 104 hp & 102 ft lbs tq, 211 SE Cam, Power Commander, T-Man Stage II Heads, Vance & Hines Big Radius 2 into 2 pipes, Performance Machine Hooligan wheels and mathching air cleaner, assorted list of mods...and always ongoing!
Old 11-06-2009, 11:35 PM
anubisss's Avatar
anubisss anubisss is offline
2002 Harley Davidson FLSTFI
I don't bother opening the reservoir. Just push the pistons back. Never had a problem. No need to rebleed.
Old 11-06-2009, 11:39 PM
stuart1270 stuart1270 is offline
Hang Around
2007 Harley davidson ultra classic
I also heard using a wood wedge to push pistons in before removing pad works great because the wood does not mark rotor.
Old 11-06-2009, 11:40 PM
anubisss's Avatar
Just use a big flat blade screwdriver to push the pistons back once the pads are in.
Old 11-07-2009, 01:20 AM
shovelheadroad shovelheadroad is offline
Hang Around
You don't need a clamp or screwdriver to push the piston back...just carefully loosen the bleed nipple and push with yer finger...it'll go back with ease.
Old 11-07-2009, 06:38 AM
tk353's Avatar
tk353 tk353 is offline
i prefer to remove the caliper and squeeze the brakes with the old pads and then remove them and clean the pistons. then open the bleeder and push the pistons back. after the new ones are installed i top off the reservoir, but not over full. ride and check level after a few miles
__________________
2007 Fatboy
Vance and Hines Double Barrel, Arlen Ness Big Sucker, Mustang seat, RearAlert
Thundermax with autotune, Cross Bones D401 200/55r-17 rear Avon Storm front 130/70
http://gallery.me.com/tk353
Old 11-07-2009, 08:52 PM
Prospect
I never thought about removing the bleeder to push the pistons back or pushing them out further. I figured only the exposed part of the pistons would need to be cleaned. Mine did not drag after the work, but then again they did not drag before either. I placed a thin piece of would between the clamp and outside of the caliper to protect it during the piston pushing process. For the cleaning I just sprayed the BPC at the pistons from the opening at the top of the caliper with it sitting up right so all the extra BPC just dripped on to a newspaper I placed on the floor. They cleaned up pretty well. My fluid looked clean so I did not bother to bleed them. I might do it with the next brake pad replacement.
One thing I did not mention is I did the procedure with the bike sitting on the jiffy stand since that positioned the reservoir in the most level position.
Cheers.
__________________
2008 FLSTF Fat Boy
Tags
boy, brake, brakes, cost, davidson, end, fat, fatboy, front, harley, hd, job, pads, replace, replacement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
Vendor Directory
New Sponsors
Advertising Information - Harley Davidson Forums - Archive - Top
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
