Progressive drop in fork lowering kit pics?
Here you go. It's a little harder than just dropping in the springs like in the Progressive advertisement. Some bikes are easy and some are a lot harder like mine. The first 2 pictures are the before pictures and the third picture is me with my tubes dropped installing the spring, I had to take all the chrome of the front of the bike headlight and aux lights and back plate to do this. The last 2 are the after pictures. I dropped mine a little over 2 inches in the front (2 1/4 inchs exactly). I would not go over 2 inches on the front if I had it to do over easily. I dropped the rear 2 inches even, and used 422 Progressive shocks to do it.
It defiantly rides harder than stock. However when it was stock it was too spongee to me. Now when I shift lanes or zig zag back and forth in the road it responds quick. I have the rears set to firm. The front springs are stiffer than stock which makes for a harder but not harsh ride. It took about a week to get used to the new ride, but I would never go back to stock height now.
I used Drag Specilties Heavy Fork Oil. Its the same Viscosity and quality oil, however you get a full quart for a lot less price than SE heavy oil. I do suggest as Bugsplat mentioned use heavy fork oil what ever the brand, not standard or light fork oil on a lowered bike.
Picture below of oil.
Before:
After:
Lowered about 2.5" up front with Progressive drop-in, and in back with Ultima adjustables.
I've got SE heavy fork oil up front, and it rides about the same as stock. It was a little soft up front with the standard oil. Took probably around 3 hours to install, taking my time. Not really difficult, but more than I originally thought it would be.
After:
Your bikes do look good, I just lower my bike 1 inch with progressive lowered forks springs, the guy at progressive told me that I do not need to use the heavy oil but listing to you guys I am wonder if I went wrong. Right now I just put the shocks back on the bike and I would hate to remove everything to change the oil have you use the regular Harley oil?
If you're happy with the ride, leave the standard oil in, but if it feels soft to you, change it out to the heavy would be my recommendation.
