Jockey shift with hydraulic hand clutch
Just curious if anyone knows where I can find a jockey shifter with a hydraulic hand clutch on it. I'm not a wrench yet by any stretch of the imagination so unfortunately building it myself is not an option( in my defense I am currently taking a course on engines and I'm considering getting certified). Just to make sure I'm asking for help on the right thing, I'm looking for jockey shifter with a hydraulic hand clutch on it so that I don't have to operate a foot clutch as I feel way more comfortable being able to put two feet down if I need to when I stop. Thanks for any help guys.
I might have read your post wrong. Are you looking for a jockey with a hyd hand clutch attached to the shift lever? If so I think that might not be something that anyone sells. Thinking about it I don't even know where you would begin in fabing something like that up as the fluid reservoir would have to be on the shift handle itself.
I'm not baggin dude, but it seems way safer havin both hands on the wheel. Think about it when you take off sometimes you wobble around. I ride w/ a jockey it seems safer anyway. Having said that no I've never heard of a hydraulic set up. A cable actuated one would be fairly simple to build.
If you like using both feet, it really isn't too much effort to slide the bike into neutral and coast to a stop. I for one would highly recommend rethinking your approach and going the foot clutch route instead; if you are hesitant with the idea you may want to consider a rocker clutch (which has a friction disk to hold the heel & toe pedal in place) instead of a suicide ("car style") clutch like the LaBriola.
