?Using Easybrackets on Hard Bags on Softail?
Is anyone using the easybrackets hardware on a set of hard bags like the touring ones on their softail fatboy? I like the idea of quick detachable bags but don't want the mounting hardware to remain on the bike. I currently use the easybrackets on a set of leatherworks leather bags but want to change up to larger hard bags. I'm using the fender holes spaced at 9 1/2" and the appropriate easybrackets and mounting hardware. Yes, I'm running with lowered python long shots and the rear turn signals have been relocated so I know I have enough room for the larger touring saddlebags.
If you are using them, please post good pictures of how and where you mounted the easybrackets to the hard bags.
I looked at mounting a set of hard leather Roadking bags on my Heritage. I have easy brackets on my stock bags and thought I could swap them onto the RK bags. With the stock heritage seat on the bike there is interference with the lid of the bag when it is opened. With the narrow seat you have on your FB it might work, at least with the leather RK bags. I'm not sure about the hard plastic bags, but make sure you check the seat clearance.
I'm using the easy brackets with my hardbags.
I'm like you, I want the security of hardbags plus the carrying capability but I also want to be able to take them off quickly with the least amount of visible hardware. The easy brackets work fine in this regard.
The only problem you're going to find is the weight of the hardbags. Using just the easy brackets, they will tilt inwards and look like ****.
I've come across a 35mm chrome bracket, which will wrap around the rear tire and fastens to the bottom of each bag for stability. It should be here in the next few days. If you like, I'll post up picks when I have it installed in the next week or two.
If it does the job I am hoping it will do, I will be very satisfied.
Lee
Lee
the new hd convertible has a good ideal for the bag support but i dont see why the easy bracket would not work. if you felt the bag was not strong enough then you could make a L bracket to reinforce the easy bracket. i have large soft bags on mine and use the short easy brackets and they hold a lot of weight. at least 2 six packs
Lee
Lee
