procharger vs.big bore kit????
I was looking at puting a big bore kit on a 88ci on my 06 duece. What are the pros and cons of doing this? I was looking at the numbers on supercharging this engine and they are pretty impressive. What are the pros and cons with the supercharger? Is there anyone already running a supercharger on a 88ci on this forum? If so do yall have any actual dyno numbers? Thanks for any info and help.
JMHO here, but the Pro Chager set up is just plain "anti Harley" on both sides of the bike. It's bulky intercooler, and all of that modern plumbing overtakes the classic, old school lines of a Harley engine. If you want more speed, buy a Kawasaki.
If you have your heart set on a conversation piece, I would go the Magnacharger "roots" blower route. Still looks Harleyesque and old school..
I have had fast rice bikes before, so I think I know what fast was. A beefed up Harley ain't fast in any modified form when compared to "fast" imported bikes..
All I did to my bike was drop a 95" kit in it, sent out the heads and installed a 204 cam. It has all the power and torque I need.
Thanks for the info and advice. I was wanting a little more umff. That is the only reason I was toying with the idea of a procharger. All I will be doing with my bike is cruising no drag or strip but we all know when you get on those long streches of highway out in BFE you like to open it up. Big bore is the way to go then keep it all natural in a sense.
There is a very noticable difference with the big bore kit. For what it is, my bike flies. I can take any of my friends stock 96ci's. Personally i wouldnt do the big bore without adding cams tho.
I can tell you this, I can thump my buddies Honda 600 crotch rocket, and I weigh 260 lbs.
Power from the head work with the 204 is solid from idle up to 4000 RPM with no soft spots. There are lots of cam debate, but I feel the SE 204 is simply the best of everything when it comes to a street cam. It's essentially the same grind as the old Andrews 37B. It thumps right off of idle and has a ton of top end.
The key is having your heads worked.
