Softail Baggers Only...Pics please
Old 03-09-2017, 07:37 PM
madjeeper's Avatar
madjeeper
madjeeper is offline
Default My Flstc 2008
96" to 103" with 101TQ 116"TQ
Fun Bike.
  #1312
Old 03-13-2017, 12:46 PM
BikerPepe`'s Avatar
BikerPepe`
BikerPepe` is offline
Received 3,846 Likes on 1,354 Posts
old pic before the last total/rebuild...
  #1313
Old 03-13-2017, 12:57 PM
sailmotion's Avatar
sailmotion
sailmotion is offline
Received 7,838 Likes on 3,236 Posts
  #1314
Old 07-31-2017, 09:58 AM
rickyk138's Avatar
rickyk138
rickyk138 is offline
Stage I
Default 2003 Softail Standard Bagger
I have followed this post for awhile and still could not find an answer about the crash bar and lowers on a softail. So I bit the bullet and bought a used touring crash bar and come ebay lowers and began work. The crash bar will not fit with out some modifications, but it will work.
The pictures below are when I first mounted everything up, but I was not happy with the height of the lowers and have since raised everything up some.
Some points to note...
-If you mount the crash bar to the stock upper mount point on a softail the lowers will sit to low and foot room is cramped, not to mention dangerous as it is hard to find the brake pedal and shift without hitting the vent control with your foot.
-Custom brackets are required to mount the lower mounting bolts also and will not go in the factory softails holes. In my first attempt I simply made brackets to extend the crash bar out about 1 inch forward on the lower mounts (can be seen in 2nd pic) and it worked, but again they were too low and had to make changes
-The touring crash bar mounts about 3.5 inches higher on the frame on the touring models. I made a bracket out of 1/4 inch stainless to raise the upper mounting point up to match the touring models
-By raising the upper mounting point, the lower mounting point for the crash bar would no longer align and I had to move and remake brackets for the lower mounts, and they would no longer reach the factory engine guard mount. I had to remove the foot pegs and use the front most bolt that holds the foot pegs on to hold the new bracket.
-Some trimming was required on the right side lower fairing to clear the brake reservoir and pedal shaft.
It is not a very hard task to get this done, if you have some mechanical ability you should have no problem doing it.
The bike is currently in the shop getting a new ring gear and starter put on, (117 like to kickback if you forget the MCR's) so I don't have pics of the final set up right now, but will try to get them up later on.
The following 2 users liked this post by rickyk138:
Dbearjr (12-03-2020), Minister1955 (07-31-2017)
  #1315
Old 07-31-2017, 10:36 AM
Bluraven's Avatar
Bluraven
Bluraven is offline
Nice to see at least somebody make the attempt to get OEM lowers on a Softail.
Like anything I knew it could be done.
However I figured that it would be a PITA to fit or otherwise there would be more reviews of those who have done it.
I ended up going with the Leather Pros lowers and beside the price **ouch!!** I'm very pleased with their function and look.
  #1316
Old 07-31-2017, 01:06 PM
Geoff's Avatar
Geoff
Geoff is offline
2007 Fat Boy
  #1317
Old 07-31-2017, 02:48 PM
ebucky's Avatar
ebucky
ebucky is offline
Stripped
Loaded
Santa Monica pier at the end of RT-66
Made my Night train a bagger for a RT-66 trip a bit ago. Bike looked and handled well enough and had no real problems on the trip.
  #1318
Old 07-31-2017, 03:53 PM
Traditional's Avatar
Traditional
Traditional is offline
Originally Posted by ebucky
Stripped
Loaded
Very nice additions to your bike for a road trip.
ebucky (07-31-2017)
  #1319
Old 08-17-2017, 07:15 AM
GRWHD's Avatar
GRWHD
GRWHD is offline
Going to go through this thread, and will add mine to it once I get her done.
  #1320
Old 08-17-2017, 02:02 PM
Sticks24's Avatar
Sticks24
Sticks24 is offline
Quick Reply: Softail Baggers Only...Pics please
