SE Heavy Breather for Rocker - need help
I received it and tried to install today. But i am doing something wrong or i have wrong part. I purchased SE Heavy Breather fits 08 - later dyna/softail models. part no. 29080-09. Does it fit Rocker? Propably not, but what the hell they say it fit 08 later softail? I dont get it. Attached picture where is visible the problem with fiting.
can anyone tell me exact part number of SE Heavy Breather for Rocker?
That doesn't even look close to being right. I can tell you that they do not make a different kit for the rocker. The intake and motor is the same on a rocker as it is on any other 96ci. That looks to me like they have the wrong part in the wrong box? I installed my Heavy Breather on my Rocker and it was a direct bolt on. Good luck and I would take that back where I got it and compare it to another one.
I checked again the part number. I found out that correct order number for softail is 29098-09. I dont get it, i would swear that 14 days ago when i was purchasing the kit, there was there different order number - the one i have. I checked twice before i made order that it fits softail, you can see its also on the box?! Now the same site says its for Sportster. So i should stop drinking or i dont know. Now i am realy pissed because i can not send it back due to the scratches which i did not do it btw.
thanks, yes its clear i got wrong part now. wondering if there was mistake at the site when i was ordering the part or i did the mistake. They might realized mistake and correct it, but who can i prove it...... Also that label on the box is strange...... I will propabaly try to sell it to someone with Sporster with discount. There is 2 scratches which are from bottom so normally no visible.
