will a 07 heritage solo seat fit a 07 fxst
after a 6 hour ride my **** cant take anymore because im 6,4 i seem to sit right back against the back of the seat and as the fxst has a high step at the back it rubs the skin of my tailbone so the heritage seat is alot flatter and soft as i am looking at going that way .i just dont know if it will fit up ok as the fxst has the wider *** end than the heritage and the bracket on the back of the heritage is different plus my main concern is the clearance over the module on the guard
I don't know how this could be a direct swap. I have owned/own both... an 07 fxst has a singular screw mount at the back of the seat for the stock seat. The Heritage has to mounting screws that go thru a plate at the back of the stock heritage solo. You would have to drill the holes for those two mounting screws that come up from under the fender and are held in place by a plate.
The frames should be the same but the fxst has a bobtail fender of course and then Heritage does not as well as the FXST being a 200 rear end. So if there is any geometric difference between the two I could not tell you. It may or may not fit right or it may. Easiest thing to do is find someone with an 07 Heritage and lay the seat on your bike to see.
Let's see if this works...
https://www.hdforums.com/forum/membe...-bike-017.html
You see the two acorn nuts right behind the seat... there is a plate under there that the screws come up thru and the acorns hold it down. Not stock those are but you should be able to see the mounting difference.
Not a direct swap unless your FXST is already setup for this.
listentothenighttrain
08-15-2017 11:23 AM
