Noise from left rear axle area
I have a noise coming from the left rear axle area on my deluxe, it's a ting-ting- ting. sound. Its most pronounced when I'm slowing with the clutch in, although I can detect it while the engaged in gear also. It sorta sounds like the noise when your car brake pads are thin enough the little metal tabs touches the rotor. I don't usually hear it on short rides, but on long ones when things get warmed up real good, its definitely there.
I never had the noise until I put axle covers on. I thought it was the retaining clip for the axle nut, but after running some teflon tape around the end of the axle and reinstalling the clip I still have the noise.
I guess if it were the wheel bearings it would be more of a grinding sound?
if anyone has any Ideas I'd appreciate it. BTW the bike only has 3000 miles on it.
Here's what I would do if that happened to me. I would ride it until I could hear the noise, go home and jack it up on my J&S lift. With the bike in neutral I would rotate the wheel by hand and listen for the noise. If that didn't work I would crank it up and put it in gear(s) and accelerate trying to pinpoint the origin of the noise. I would be comfortable doing this on the J&S jack, not sure about any others.
