Pre-wired apehanger kit vs DIY install with Novello wiring extension kit?
Old 04-12-2010, 07:01 PM
thewholehog's Avatar
thewholehog
thewholehog is offline
Default Pre-wired apehanger kit vs DIY install with Novello wiring extension kit?
Hi, I am putting 12" apes on my FLSTN and it will require wiring extension and new cables.
How hard is the extending and internally wiring part of the job???
  1. Should I get the internally pre-wired HCC bars?
  2. Or should I do it my self using one of the kits eg Novello?
Thanks.
Old 04-12-2010, 07:03 PM
DR. V-TWIN's Avatar
DR. V-TWIN
DR. V-TWIN is offline
Former Sponsor
Do it yourself. The novello makes it easier as they are color coded, but if you know how to solder you can just solder them on. If you don't have time or the skills to do this pay for pre wired, but it is not that hard. If you do solder them stagger the cuts so there is not a big lump in the middle of the wires as they still have to be pulled through the bars.
Old 04-12-2010, 11:07 PM
RedBen's Avatar
RedBen
RedBen is offline
When I extended mine, I just went to the local auto shop, bought the right gauge wire and soldered it on. I used a sharpie pen to mark each wire so I knew which one was which. If you don't want to solder, crimp connectors also work. The other way to go other than pre-wired bars, is to buy a new switch wiring harness. I don't know if Dr V-Twin carries them or not, but JP Cycles has complete switch kits for $99 with 48" wires attached with either black or chrome switches. You can get new switches and extended wiring harness from HD as well. Soldering your own is definitely the cheapest way to go though, even if you need to buy a soldering iron.
Old 04-12-2010, 11:40 PM
thewholehog
Thanks, the HCC pre-wired bars come complete with switches also.
BigGelvis
03-05-2013 08:14 AM
Titan56
01-16-2010 10:41 AM
chromedome
11-26-2008 12:45 AM
BadPiggy
03-17-2008 12:22 AM
jrow1010
03-09-2007 10:53 PM
Quick Reply: Pre-wired apehanger kit vs DIY install with Novello wiring extension kit?
