Removing Rear Fender Bolts
Finally got some time Friday to try everything out. What a nightmare this was!!!!! Got two of the four bolts out I needed by whacking them loose with a hammer and heating them up a bit. The other two I had to cut the heads off and get out with vice grips. I ended up having to destroy one of the docking posts for the detachable backrest, but that part was only $7. Once I got the new bolts in they were too long. It looked like they could hit the rear tire if I went over a big bump. So back out they came to cut of a little bit of the ends. Took me about 3 hours to remove 4 bolts when it was all said and done
So Friday I'd had it and decided to finish the saddlebags Saturday. So on Saturday, the saddlebags went pretty smooth other than the 3/8" drill bit required to drill holes in them was the one bit I didn't have Anyway, got everything setup Saturday and the new saddlebags look and work great. I wish they were a bit wider, but at least they're not in the wife's way. Thanks everyone for all the suggestions, I think I used pretty much all of them.
fender bolt
I am trying to install saddlebag brackets on my 2016 harley sportster seventy two. The shock bolt came out just fine but the rear bracket support bolt is turning with the nut. How do you get a wrench in there to hold the nut as there is barely enough room to get your finger in there. Appreciate any suggestion as I am not going to pay the Harley dealer 110.00 to do the job.
Regards
Walter
Regards
Walter
Regards
Walter
Regards
Walter
Good luck.
Hopefully he's over it by now. That was 6 years ago.
lmbo...Bones, damn it, man.I know to look at the original post date first. Too funny!
