LaRosa Swing Arm Bag and Rigid Brackets
Old 04-26-2010, 03:52 PM
Mario77746's Avatar
Mario77746
Mario77746 is offline
Default LaRosa Swing Arm Bag and Rigid Brackets
First, I have to thank WARG for coming up with this idea first. I simply copied it to fit my bike.
I bought a new LaRosa bag off of ebay for $108 shipped. The dimensions are 14x7"x4". It has double stitching and the inner wall is 2 layers of leather. I removed the leather straps to attach it to the swing arm and went with the setup below.
I went to Lowes and picked up some shatterproof 8x10 plexiglass and the necessary hardware all in 5/16. 3 couplings. 6 1" bolts, lock washers, fender washers and nuts. Total cost $15.
Next attached the couplings and bolts to the bike. I used a drop of locktite on the couplings. Then one of the plexiglass sheets. I free handed the bag against the sheet, marked it and trimmed it.
Next I placed the 2nd plexiglass sheet on the back of the bag and measured it to fit inside the bag. After cutting it I took a file to it to get rid if all the sharp edges. Next, (not pictured) match the holes up to the plexiglass on the bike then drill them into the bag.
Place that plexiglass sheet in the bag and attach the bag to the bike. The bottom bolt only holds the 1st plexiglass sheet to the bottom of the bike. I drilled a hole through both plexiglass sheets and the bottom of the bag to give it more support.
And your done..............Not bad for $123 and about 1.5 hours of work.
Old 04-26-2010, 03:54 PM
Slopneck's Avatar
Slopneck
Slopneck is offline
Looks good, man! Your work paid off.
Old 04-26-2010, 04:38 PM
Lu's Avatar
Lu
Lu is offline
Awesome Job!!!!!!
Old 04-26-2010, 04:41 PM
NightTrain4Al's Avatar
NightTrain4Al
NightTrain4Al is offline
Looks good! Just wondering, do you not run your belt guard? If I'm seeing the picture correctly it looks like you used the mounting tabs that hold the belt guard on to mount your bag to.
Nice work!
Old 04-26-2010, 04:46 PM
meatsack's Avatar
meatsack
meatsack is offline
Dumb question....do you have a sheet of plexi on the inside AND outside of the bag? What was the reason for two? What length of couplers did you get?
Old 04-26-2010, 05:23 PM
thornious's Avatar
thornious
thornious is offline
Looks great and great idea on using the plexi
Old 04-26-2010, 09:26 PM
deadeye's Avatar
deadeye
deadeye is offline
Awesome instructions. I've seen a few of these swingarm bag mount threads but I'm always left wondering exactly what kind of hardware is required. Anyone in the US can find this stuff easily, but for military overseas (or any riders outside the US) its not so easy to find SAE hardware like the couplers. There is money to be made for somebody to put together mount kits like this.
The ultimate mount would have hot rod hood quick release pins inside the bag screwed into the couplers. The bag could be removed in seconds for washing but still be very secure.
http://www.hrpworld.com/index.cfm?tp...action=product
Old 04-27-2010, 01:18 AM
kiwideuce's Avatar
kiwideuce
kiwideuce is offline
nice job!!can i ask you what you think of the quality of the larosa bag! i have seen them on e bay too! i thought about getting one but some posters say they not so good! i no garage leathers are the best!!but does it feel strong?? is it good?
thanks
Old 04-27-2010, 04:02 AM
deadeye's Avatar
deadeye
deadeye is offline
thanks
I've had both larosa and leatherworks. The larosa bags are made of thick enough leather but they don't have quick release buckles and the leather isn't finished very well. So, the larosa soaks up more water when wet and starts looking crappy and loses its shape after a few months. If I took better care of the larosa and put lots of leather dressing on it could have lasted longer - but since I use it a lot for mail and whatnot, I got a better bag with quick release buckles.
Old 04-27-2010, 07:53 AM
WARG's Avatar
WARG
WARG is offline
looks great. Great idea on the plexi!!!
Quick Reply: LaRosa Swing Arm Bag and Rigid Brackets
