Car Tire on my 07 Night Train
Well, it took some doing and I tried 2 other tires before I found one that would work. It handles decent and the rubber is a softer compound than the stock Dunlop wide tire on the wide tire Softails. The fingernail test never lies.
This Falken is rated for 40k miles but I think I'll probably only get 30k out of it. Did the change myself because it's almost impossible to find anyone around here to do it. That's ok though 'cause I only have to do it every 5 or 6 years now rather than every year. Did you know it's a pain to change out the tire on the wide tire Softy's?
When I get some more miles on it and dial in the air pressure I'll come back and give an updated review.
Feels and looks good so far though.
Pics to follow as well ...
PS: I'm not advocating anyone use a car tire on their bike. just relaying my experience with one. As far as I know, the only HD's this works on, are the wide tire Softails and the 09 and later Electra Glides.
Edit: Others have also successfully used the following tires on the wide tire Softail's.
-205/55ZR17 General Exclaim ---- Old Coyote
-BF Goodrich g-Force t/a KDW2, 205/50ZR17 ---- Red9
I've seen this done on a few metrics before. In fact a guy I worked with had one on his Honda. I'm not that cheap to try a car tire. I will say that if it's rated at 40k then it aint that soft. Plus a car tires tread is flatter than a bike tire. To each their own. I'll stick with my Avons. One thing to think of is that tires harden over time with each heat cycle, Good luck and ride safe
I did it myself. I picked up a Harbor Frieght tire changer and some long tire spoons. I was able to easily remove the old tire and get the first lip over on the new tire but the final lip had me on the floor with some 4x4's under it to protect the sprocket. I could have used another set of hands but I got it done anyway. I used 3 oz's Dyna Beads to balance it.
The tire seated easily. I started out with 50 psi which is labeled as max for this tire. I'm down to about 47 psi and noticed a significant improvement. I suspect I'll find the sweet spot in the 42-45 psi.
Edit: The magic air pressure for this tire on this bike is 40 psi. Any lower or higher and the handling degrades somewhat.
You are very correct B&C. I figure to get 5 or 6 years at the most out of this tire and would need to be changed by then anyway. Most people using this tire, if the reviews are to be believed, only get about 18-20k miles out of these tires.
It does ride differently. It takes a little more effort to go from going to the right to going to the left and visa versa. I figure I'll be used to it by the end of today's ride.
As a rule; car tires are made of a softer compound than MC tires. This Falken tire is a high performance tire which makes the compound even softer than standard car tires.
I'll take a longer ride later today to see how it feels on the highway. This tire is shorter so I picked up some quickness off the line. I'm hoping 6th gear will be perfect now. With the MC tire I couldn't really get into 6th until 70 mph. If I can comfortable get into 6th at 60 mph I'll be happy.
Here's a couple of pics ...
Before CT
Before CT
Hey Boomer... It looks good. You just take it easy brother you got lots of time to get used to that car tire. Good on you for trying something new. Has anyone said how it reacts in wet weather? Being more flat I wonder if there a more chances of hydroplaning. Just ride safe while you feel it out brah.
I'm with you brother......Screw all the tire companies and their fancy research on how to design tires for specific application, like motorcycles.(I'm sure they only spent millions). That flat tire with the almost 90 degree edges will work much better for cornering rather than the gradual slope of mc tires. Good luck at any rate........................
