1998 Fat Boy - Circuit Breakers
Old 05-29-2010, 07:36 AM
MrVertex's Avatar
MrVertex
MrVertex is offline
Stage IV
Question 1998 Fat Boy - Circuit Breakers
When I was trying to start my bike for the first time this season I lost all electrical power. Assuming it ws a circuit breaker I found a box of 4 breakers under the seat next to the battery. Swapped out each one but still no power. Are there other breakers or is there another problem?
Old 05-29-2010, 11:52 AM
DR. V-TWIN's Avatar
DR. V-TWIN
DR. V-TWIN is offline
Former Sponsor
Did you check the battery cables? Make sure they are tight. Also check the ground for the battery cables. That is where I would start.
Drew
Old 05-29-2010, 12:08 PM
MrVertex's Avatar
MrVertex
MrVertex is offline
Stage IV
God suggestions. I failed to mention that I was cranking gthe bike and trying to start it. I had cranked for several minutes when I lost the electrical power.
Old 05-29-2010, 12:12 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Sounds like you have a short somewhere. Maybe a bit of exposed wire that is touching metal. Fuses are all good I assume? Sometimes jiggling the relays will help too.
Old 05-29-2010, 02:28 PM
piperbob's Avatar
piperbob
piperbob is offline
Main breaker is on the fender behind the tranny.
Bob
97 Heritage
Old 05-29-2010, 05:56 PM
MrVertex's Avatar
MrVertex
MrVertex is offline
Stage IV
The box for circuit breakers is on the rear fender as you say. It has four 15 amp breakers that I swapped out 2 at a time with the two new breakers I have. No change.
Since there is no power anywhere, is there a main breaker also?
Old 05-30-2010, 05:05 AM
piperbob's Avatar
piperbob
piperbob is offline
Read my last post, I did'nt say it's in a box.
Bob
97 Heritage
Old 12-23-2016, 09:34 PM
chuck13's Avatar
chuck13
chuck13 is offline
Stage I
I know this thread is old, but having the same issue with a 98 FXDWG, I can't find the main to test it. Any help would be appreciated.
kenneth161
10-10-2023 11:47 AM
Techgnosis
Electrical/Lighting/Alarm
01-16-2019 05:56 PM
Bhamguy
03-13-2018 06:59 PM
Butcheebear
02-24-2017 07:06 PM
85RoadsterXLS
11-15-2016 11:50 AM
Quick Reply: 1998 Fat Boy - Circuit Breakers
