Raising Fuel Tank
Old 06-02-2010, 09:02 AM
dennyo's Avatar
dennyo
dennyo is offline
Received 1,054 Likes on 630 Posts
this is what 2-1/4in. looks like ,, I used a piece of Muffler sStrap
Old 06-02-2010, 12:56 PM
handyhoward's Avatar
handyhoward
handyhoward is offline
Originally Posted by jlasoftail
what affect would all this have on the "remainder" display on your guages to show you how much further you can go before pushing? and has everyone else that did this have to change the lines? the kit on ebay sais they include the new ones, but you shouldn't have to use them...
It will change the gas gage accuracy... like it is accurate to begin with. I figured out how far I could go three times by running until I was out of gas... had a backup bottle with me. All three times I went 221-223 miles... now I know when to stop and how far I can go. No inaccurate gages or lights or worries.......The reason for the longer crossover line in the kit is because if you only raise the tank an inch or so the gas line won't fit above the frame backbone... if you go up high enough, the regular crossover line will fit between the tank and the backbone... no need for a longer line.
Old 06-02-2010, 10:11 PM
In Memoriam Citoriplus's Avatar
In Memoriam Citoriplus is offline
May our Moderator Rest in Peace
Originally Posted by rowdy82
Not sure if its true, but i've heard that its easier to burn up your fuel pump when you do a tank lift on an EFI bike also.
Originally Posted by handyhoward
Why would you believe this... the fuel remains level inside the tank... the pick up remains the same...
Not to sound like a smart ***, but when you think about it, that makes no sense at all.
While the pump itself 'might' sit up out of the fuel for longer periods of time if you like to run your bike below half a tank all the time.
The pump doesn't depend on the fuel surrounding it for cooling as much as it uses the fuel flowing through it for any cooling needs.
So I have to believe that 'lifting a tank means cooking a fuel pump' is one of those now so bright things said by people who don't think things through very well.
Old 06-02-2010, 10:44 PM
bmr's Avatar
bmr
bmr is offline
I raised my tank about 2 1/4" with a couple of u-bolt braces I picked up at lowe's for about $2. I got a section of fuel line and some hose clamps at the local auto parts store and some chrome acorn nuts from ace hardware. Total investment about $15. Don't forget the blue loctite.
Attached Thumbnails Raising Fuel Tank-tank_lift-005a.jpg   Raising Fuel Tank-tank_lift-006a.jpg
Old 06-27-2010, 11:15 AM
chad pickens's Avatar
chad pickens
chad pickens is offline
I made my own with a sheet of steele and a bandsaw. Drill a hole in each end and used some old stainless bolts from old projects. I raised the front 1 3/4".I also raise the rear 3/4" it gives a slight amount of angle change.But it gives alot motor clearance. I reused the stock rubber hose but relocated it above the frame brace.
Avalanche_Mutt
03-23-2011 06:28 AM
mikebaby
Carburetor Related
10-08-2010 06:57 PM
ponch3640
05-05-2010 06:36 AM
bncer18
04-27-2009 12:11 PM
Leonc69
04-08-2007 04:00 PM
Quick Reply: Raising Fuel Tank
