Steering Bump Issue - Forks hit tank
So I put this "Fat Kid" kit from JP cycles on my 2003 Deuce, which is basically a FLST front end and I have an issue...the forks hit the gas tank at full steer. So I think I need to put in some sort of spacer in the lower triple tree to stop this. My question is how should I go about this? Glue in a rubber spacer, weld in a piece to fill the gap? Or whatever.
Looking for some advice. Thanks.
I did find some resources for different fork stops, most look like they involve drilling and tapping into the lower triple tree. My short term plan is to take a small piece of square stock and JB Weld it into the space on the lower triple tree and see how that works. That way I can avoid welding and/or major modifications.
Pro One has an internal fork stop kit.
Pretty simple install, hardest part is taking the old bearing race out.
http://www.pro-one.com/103413_Fork_S...t_p/103413.htm
katanaplanet
09-05-2014 11:52 PM
PoBoyGlide
02-11-2008 11:44 AM
Mississippi Bagger
01-24-2008 03:30 AM
