LED tail light bulb doesn't work?
Old 06-12-2010, 11:35 PM
av8or's Avatar
av8or
av8or is offline
Default LED tail light bulb doesn't work?
I might be showing my stupidity here so take it easy on me. I just tried to change the bulb in my tail light to an LED. It worked but my turn signals stayed on bright all the time. I have the HD run/brake/turn module on the bike. Do I need a load equalizer or something?
Old 06-13-2010, 01:06 AM
In Memoriam Citoriplus's Avatar
In Memoriam Citoriplus is offline
May our Moderator Rest in Peace
Your not showing your stupidity, just ignorance.
Stupidity is incurable, ignorance can be fixed with information.
It sounds like you put in a simple LED replacement and its lower resistance value is probably playing merry hell with the electronics in the run/turn/brake module.
So you can either take the LED out and replace it with something like a Sylvania SilverStar bulb (very bright but still an incandescent) that will let the module work properly.
Or leave the LED in and pull the module out.
There is another option where you can rewire the module to operate as a brake/turn only that should fix things.
I did it to mine and with the TriBar and LED turns it works just fine.
Don't even need an equalizer for the turn signals now.
Check out this thread for instructions on how to rewire the module for turn/brake only operation.
https://www.hdforums.com/forum/touri...ion-kit-2.html
And remember there is no such thing as a stupid question, or if there is its invariably the one you don't ask. Cause the answer to that one is likely to be the one that keeps you out of trouble, saves you money, or both.
Ride safe,
Jerry Pbury
06-08-2015 11:00 PM
Bearcat1
04-27-2013 09:49 AM
JAE88
09-11-2012 03:24 PM
DEMIGOD
04-16-2008 08:26 PM
1nuckenfut
02-18-2008 11:20 PM
Quick Reply: LED tail light bulb doesn't work?
