heel toe shifter
Old 09-06-2010, 06:01 PM
ambrose's Avatar
ambrose
ambrose is offline
Default heel toe shifter
Is it possible to put a heel-toe shifter on a 2008 Fxstc.
Old 09-06-2010, 09:53 PM
meatsack's Avatar
meatsack
meatsack is offline
Anything is possible with a couple beers and a welding tank...
Old 09-06-2010, 09:57 PM
Nubz's Avatar
Nubz
Nubz is offline
don't forget the cutting torch tip and a hammer
Old 09-06-2010, 11:42 PM
Mr. Lucky's Avatar
Mr. Lucky
Mr. Lucky is offline
Old 09-07-2010, 04:41 PM
ambrose's Avatar
ambrose
ambrose is offline
Will the OEM shifter off a street glide fit my 2008 Fxstc, the sproket should be the same correct?
Old 09-07-2010, 06:53 PM
Mr. Lucky's Avatar
Mr. Lucky
I'm not sure what you mean. There are no sprockets in a Harley shift assy. The lever from an FLHX will fit, but you need that DS p/n listed in my other post to get the replacement inner shift arm with the longer spline shaft.
Old 09-07-2010, 08:16 PM
ambrose's Avatar
ambrose
ambrose is offline
If I use a one peice shifter it should be ok right? the shaft where the shifter slids on is the same size, right or wrong?
Old 09-07-2010, 09:02 PM
Mr. Lucky's Avatar
Mr. Lucky
As long as it's intended for a big-twin... correct. Sportsters have a different spline count. A 1-piece shifter (like the Dewey's Heel Hammer or the Tejas Thump Cycles unit) costs a lot more than than a replacement inner shift arm though (less than $10 as I recall), and you should be able to get an FLH shift lever for free, since so many dresser owners remove their heel shifter.
e11charlie
07-02-2020 06:48 AM
Skippy97
09-21-2012 12:02 PM
Crusher
10-04-2011 02:50 PM
JacktheBagger
10-02-2008 09:21 PM
Quick Reply: heel toe shifter
