softail springer front wheel
Old 09-07-2010, 06:06 PM
JWOC's Avatar
JWOC
JWOC is offline
Default softail springer front wheel
Does anyone know if a 1999 softail standard front wheel will fit on a 2006 softail springer.
Old 09-07-2010, 07:41 PM
Harlie Rider's Avatar
Harlie Rider
Harlie Rider is offline
Smile
You need a wheel designed for a Springer.
When I purchased the Hallcraft wheel for my '96 BadBoy, every mfg I got a quote
from told me to be sure and buy a wheel engineered for a Springer. They said because
the weight of the Springer frontend and flex the forks would have if an improper wheel
was used.
Old 09-07-2010, 07:43 PM
hspring03's Avatar
hspring03
hspring03 is offline
A 99 wheel will have different bearings and different axle than the Twin Cam 06
Old 09-08-2010, 11:39 PM
smketr7139's Avatar
smketr7139
smketr7139 is offline
yep I just found this out as-well...I currently have a 1999 Softail Springer and I am wanting to purchase a twin cam Heritage Springer and do a 21 inch front wheel swap, I was told you can keep your factory (twin cam) hub and just have a 21inch rim laced to it
Old 09-09-2010, 08:28 AM
FastHoss's Avatar
FastHoss
FastHoss is offline
That is the way to go but don't know if you ever rode on a skinny 21.I don't like how they handle and they wear out quick.
JTM
Wheels/Tires
03-21-2011 06:53 PM
cirhere2
12-05-2008 06:13 PM
ChopperHammer666
11-09-2008 06:48 PM
hdkevin95
01-13-2008 06:01 PM
BVBOB
09-18-2006 05:57 PM
Quick Reply: softail springer front wheel
