Changing Throttle Cables...
Old 10-29-2010, 10:25 PM
AusMongrel's Avatar
AusMongrel
AusMongrel is offline
Default Changing Throttle Cables...
Hi Guys,
The work continues on my Fatty, and now I am about to attempt to swap out the throttle cables for braided ones...
Questions is... Do I need to remove the tank? Please tell me there is an easy way.
Old 10-29-2010, 10:28 PM
Kowan's Avatar
Kowan
Kowan is offline
On my Rocker, I didn't need to remove the tank when I installed my braided cables. I was able to sneak them down after loosening the tank enough to lift it to clear a bit.
Old 10-29-2010, 10:29 PM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,570 Likes on 2,888 Posts
Nope. Gotta pull the tank. Its easy. If its EFI the fuel line is a quick coupler and you cut the clamps on the front balance line and the dash is one nut and a few elec conectors. Good time to fab up a tank lift too.
DR. V-TWIN's Avatar
DR. V-TWIN
DR. V-TWIN is offline
Former Sponsor
Or you can jsut slide the tank back by removing the front and rear bolts and unplugging the gas line. It sure is easier to get in there with the tank slid back.
Drew
Old 10-29-2010, 10:31 PM
soft 02's Avatar
soft 02
soft 02 is offline
Wow never thought of that. Thanks for showing me up agian Drew.
Old 10-29-2010, 10:33 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Just trying to share some info and make things easier. Glad to be able to help.
Drew
Old 10-29-2010, 10:35 PM
AusMongrel's Avatar
AusMongrel
OK.. I had a look at the balance line. If I disconnect it, surely the tank will empty itself on my floor. So... best to drain it first I guess.
I have the tank all undone, but cant get enough room.
What a pain!!
Old 10-29-2010, 10:38 PM
soft 02's Avatar
soft 02
soft 02 is offline
Take the squeeze clamp off of the main pressure like and installa long line going into a coffee can or somthing and turn the key on and let the pump do the work.
Old 10-29-2010, 10:39 PM
soft 02's Avatar
soft 02
soft 02 is offline
I meant line instead of like...oops
Old 10-29-2010, 10:51 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
I'm telling you, just slide the tank back as opposed to getting gas everywhere. No matter how neat you are, it will spill somewhere.
Drew
Quick Reply: Changing Throttle Cables...
