Battery
Dont have a battery tender. Battery 3+ yrs old, stock HD. Suggest your charging system has a malfunction, or you have many extra or hi power accessories. Manual has good trouble shooting advice, start with a quick meter read for 13.75 or better at 2000 rpm at the battery posts. Check that the posts are tight.
It sounds like something is draining your battery. I had an issue where a wire was crimped improperly on my circuit breaker that killed 3 batteries in a row. My first battery lasted 5 years and I have never used a tender. I do ride at least 3 times a week weekly. Get out the multi meter and start checking for shorts. Have you added something recently before your battery started to die? Did something break and get fixed prior to this issue?
Drew
Drew
I'm still using the battery I got new with my bike in 2004. I remove it from the bike and put it on a charger over the winter. During the riding season I don't keep it on the charge. I'll probably get a new one next spring just for the peace of mind. I agree there may be something draining yours.
If you're using a quick charger your probably not helping matters either. I never put over 2 amps into a small battery like that. You can read your charging system very easily with a meter right off of the battery. Read it 'off' and read it 'running'. Should see the difference. Good article on that very thing in HOG magazine this quarter.
