Anyone do a wide tire kit on a Deuce?
Old 11-05-2010, 10:02 PM
trkyhtr113's Avatar
trkyhtr113
trkyhtr113 is offline
Stage II
Default Anyone do a wide tire kit on a Deuce?
I want to do at least a 200 on my deuce what kit have you used for this? Want to go bigger but I think cost may work out better in other ways. What suggestions do you have? any ideas? Can I get away with stock swingarm with a 200?
Old 11-06-2010, 11:01 AM
FL DEUCE's Avatar
FL DEUCE
FL DEUCE is offline
This is a 200mm tire on my Deuce. Bolted right on... no problems. It's a 2007 Deuce.
Old 11-07-2010, 12:24 PM
JAKE 2544's Avatar
JAKE 2544
JAKE 2544 is offline
I went with the hog pro 200 kit .
Old 11-13-2010, 06:39 PM
kiwideuce's Avatar
kiwideuce
kiwideuce is offline
yeah you can go 200 on a deuce,you need a 18x5.5 rim like i used! i am only running a 180 at the moment to go 200 i need the narrower 06 belt and pulley to get clearance from the tyre!! i did the job myself,just had to take a few mm off the pulley side axle spacer to allow for slightly wider hub!
Old 11-16-2010, 03:04 AM
apendltn's Avatar
apendltn
apendltn is offline
did you change your rim size to run the 180?
Old 11-16-2010, 09:09 AM
FATCAT_01's Avatar
FATCAT_01
FATCAT_01 is offline
Yes you need to change rim to 5.5" wide to run a 180.
Old 11-16-2010, 09:18 AM
DR. V-TWIN's Avatar
DR. V-TWIN
DR. V-TWIN is offline
Former Sponsor
Heartland makes a great wide tire kit for the deuce. Contact me for discounted pricing pelase via PM or email at DREW@DRVTWIN.COM
Drew
Old 11-16-2010, 08:13 PM
brihvac's Avatar
brihvac
brihvac is offline
Unless its a 240, I would'nt waste my time. Not worth the money
Old 11-16-2010, 08:15 PM
TORQUEY's Avatar
TORQUEY
TORQUEY is offline
That's some spruced Deuce you've got there!!!
Old 11-17-2010, 12:13 AM
1sssickdeuce's Avatar
1sssickdeuce
1sssickdeuce is offline
+ 1 invest in a 240/250 kit. I have the heartland 250.
Quick Reply: Anyone do a wide tire kit on a Deuce?
