Raise the fuel tank on my Deuce
Received 3,940 Likes
No problem with EFI...but you will have about 1/3 gallon less usable fuel capacity with a 3" lift.
Here's a quick way to check for clearance issues-
1. With bike on kickstand, take the bolt out of the front of your tank.
2. Loosen (do not remove) the bolt at the rear of your tank.
3. Turn your handlebars all the way to the left and raise the tank up 3 inches to check for clearance issues.
4. Turn your handlebars all the way to the right and raise the tank up 3 inches to check for clearance issues.
Click here for more info and pics on Tank Lifts
Curious to hear your thoughts...
Raising the front of the tank also raises the pickup, cause its up front too.
So you loose the use of whatever amount of fuel remains in the tank 'below' the pickup.
At 2" your going to loose about a quart or so.
The fuel gauges are notoriously inaccurate to start with so there's not much of a loss there.
Your just going to have to rely more on the trip meter, after you figure out just how far you can go, if your not doing that already like the rest of us.
Interesting, thanks. I'll have to take a gander at the service manual to see if there are any diagrams that can help me see what you are talking about.
Depending on the size of the tank and the height of the tank lift, anywhere from a 1/5 of a gallon to 1/3 of a gallon is lost in effective fuel capacity.
What the guy told you is mostly correct also- your gauge will show less fuel than you really have in the tank, for the same reason stated above. But it does affect usable capacity.
This is a non-issue unless you make a habit of running the tank to near empty.
