primary chain specs???
Primary chain tension
Deflection with hot engine 5/8-7/8 in. (15.9-22 .2 mm)
Deflection with cold engine
3/8-5/8 in. (9.5-15.9 mrn)
Chain tensioner nut torque
21-29 tt-Ibs (29-39 Nm)
Primary chain inspection covertorque
84-108 in-Ibs (10-12 Nm) -
Primary chain lubricant
Lubricant capacity 26 oz. (769 mL)
Primary chaincase drain plug torque
36-60 ln-lbs (4-7 Nm)
3. Check the primary chain tension. Push on the upper
strand on the chain to verify that it has free movement
midway between the engine compensating sprocket in
the front and the clutch sprocket in the rear.
a. With the engine cold, upward (not total) free play in
upper strand should be 5/8-7/8 in. (15.9-22.3 mm).
b. With the engine hot, upward (not total) free play in
upper strand should be 3/8-5/8 in. (9.5-15.9 mm).
anubisss
08-25-2009 11:57 PM
