extended forks
extended forks
Hi, my name is Tom from england i have just purchased a new 2007 softail custom, i wish to put a new extended front end on over the winter, my problem is which length fork tubes ie, 2 4 6 8 inch over stock etc,to match to 7 degree rake triple trees purchased from pro-one and to keep the right trail. many thanks TOM.
RE: extended forks
Cheers shooter,printed the conversion tables off,problem is i do not get motor till nov to get the required measurments,perse says to keep trail between 3.5-5 inch i got the standard rake and trail for the softail custom from the moco which is 32degrees rake 147mm trail which is approx 5.75 inch so looks like h.d. are out of the optimum parameters.{ its all getting a bit complicated my head aches} TOM England.
Received 1,211 Likes
RE: extended forks
The rule of thumb is NOT to use raked trees on a stock frame, especially 7 degree trees. You'll end up with too little or even negative trail. If you don't want to actually rake the neck of the frame, there are raked cups that'll get you 3 degrees. Then get some 3 degree trees (which gives a total rake over stock of 6 degrees), and look at 6 inch over tubes, and you'll probably be OK in the trail department. Run the numbers to be sure - a high speed death wobble ain't fun!
Or there are some kits that are designed to give you the rake without cutting the frame, and with good trail figures. These kits include trees, fork tubes, and everything else you'll need.
Bottom line is raked trees are used to correct the trail on raked frames, and should seldom be used on unraked frames.
RE: extended forks
ORIGINAL: LuckyBob
I have a question along these lines - if one was to use 3* cups and 3* raked trees, would it be possible to keep the stock fork length ( and not drag the front of the frame on the ground)? Also, any idea what the wheelbase would stretch out to? Thanks for the info.
67 LS1
09-26-2006 08:51 PM
