Clutch interlock switch
Well, I finally got around to fixing this. Obviously this was not of huge interest since no one responded. I got the switch from the dealer (~$61.00 including tax). The only issues with not having the switch operational were not being able to start the bike in gear with the clutch lever pulled in and the annoyance of staring at the red security light (error) while riding. Anyway, the replacement was fairly easy. Move the clutch lever (this time) and open the switch housing. Cut out the old switch, install the new one, splice/solder the wires, heat shrink, and close up (carefully). Clear error b1154. Good to go.
The left handlebar switch description in the Clymer manual (page 453) stated:
4. Clutch switch (2007-2009 models)
This leads me to believe there are variations for other softail model years.
I think there's another one just like it in the right switch housing so that front brake lever engages the brake light. It's shown on the blown-up diagram view. Just be careful when removing the switch housings. Be patient and always move the levers first.
Now that I think about it, I guess that's not unusual for earlier bikes. My old Yamaha would also "try" to start in gear/no clutch but at least I could push-start it if necessary. If you're not expecting it though, I could see a scenario right out of a TV comedy where you dust off a whole line-up by inadvertantly hitting the GO button.
If the cruise is electronic, I would want it to switch off if the clutch is pulled and the interlock switch would be one way to do it. My manual tranny truck does that. If you have a mechanical cruise, you would have to remember to disengage the cruise prior to pulling the clutch lever. Of course 99% of the time you would be in the process of slowing down and want to disengage the cruise anyway.
cruise has to disengage moment clutch is pulled (pushed, if in a car/truck) otherwise motor runs away. with switch broken/ not working, what signals actuator to disengage holding throttle at whatever it was set at? nothing! most likely cruise would fail to hold due to open circuit read by control unit. so you would have a problem with the switch broken, an inop cruise control!
